Re: 1949 farmall cub magneto
Posted by George Willer on January 05, 2005 at 07:21:15 from (208.252.179.27):
In Reply to: 1949 farmall cub magneto posted by DanfromKY on January 04, 2005 at 20:49:27:
Dan,
The Cub is unusual in that it's the *governor* that has to be timed correctly. This is because the governor gear acts like an extra idler gear in the mag drive train. There is a timing mark on the *rear* face of the governor gear and the idler gear that must be aligned. You may have to remove the mag drive seal in order to see it. It has to be right in order for the mag drive slot to be in the right place.
George Willer
Post a Followup
Subject:
