Re: help with 12 volt conversion
Posted by Jeff smith on January 05, 2005 at 10:58:44 from (24.218.84.18):
In Reply to: help with 12 volt conversion posted by j smith on January 02, 2005 at 14:35:36:
The generator and volt reg were removed to a shelf in the garage long ago. I will try the resistor in place of the light and see how it works. My main problem is reaching under the dash to get at everything. Taking out the battery is easy but getting a look at what you are doing is hard. I will work on it this weekend weather permitting. I used it last week to plow 13 inches of snow, so I am happy with it.
I live in Southern Mass
Post a Followup
Subject:
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
