Re: 240 S ll o www @ cranking over
Posted by Al L. in Wisc. on January 05, 2005 at 12:11:03 from (204.145.232.66):
In Reply to: Re: 240 S ll o www @ cranking over posted by Bob on January 05, 2005 at 12:04:32:
Man Bob, that was a fast response. Cleaned battery cable connections. New battery with tractor when I purchased it - about three months ago. Haven"t changed oil yet and this could be the case. I also have a terrible squeal in hydraulic pump and shut tractor down after running for a few second. This was over a month ago. Then weather got cold and I got busy, or was it the other way around??? I have to check fluid level. Is check plug on right or left side of torque tube? Need to get the manual out. Thanks for the response and any other info would help.
Post a Followup
Subject:
