Re: Hydraulic Cylinders
Posted by big fred on January 05, 2005 at 15:24:24 from (130.76.32.145):
In Reply to: Hydraulic Cylinders posted by PAULIH300 on January 05, 2005 at 15:01:37:
Paul, if that's the same loader I have, there's only one line going to those cylinders and it's at the bottom when installed. You won'd get the air out by cycling the system. You'll need to get that hose inlet to be the highest point in the cylinder and then cycle it a few times. Best way to do that is unhook (one side at a time will work) the top of the cylinder and lay the end something such that the top is lower than the bottom, then cycle the system. You'll need to push the cylinder by hand (or rig a spring or bungy setup on it) since it is single acting. Not a difficult task, but a pain in the rear nonetheless.
Post a Followup
Subject:
