Re: pack material
Posted by riverbend on January 05, 2005 at 17:03:32 from (208.160.33.53):
In Reply to: pack material posted by Wes in Ohio on January 05, 2005 at 16:12:52:
On an H, for example, there are 3 soft, fiber split washers that go under the nut and seal against the water pump shaft. Your IH dealer will have them.
Post a Followup
Subject:
