Re: 856 specs
Posted by K.B.-826 on January 05, 2005 at 17:30:00 from (209.163.43.37):
In Reply to: Re: 856 specs posted by CEB on January 05, 2005 at 08:54:58:
Not sure I agree about the tires. Many of them have 16.9x38's and 18.4x34's on the rear. 9.5x15's on six-bolt rims are the most common fronts, while many have 10x16's on 8-bolt rims. Your hydraulic numbers are wrong, too, The hitch and auxillery valves are supplied by the 12 gpm pump. I want to say that this system was originally equipped with an 1800 psi relief valve, but it may have been a 2000 psi valve. Bigger and later tractors could have 2200, 2300, and 2500 psi relief valves, which will screw right into an 856, so the only way to know what you've got is to get it on a flow-rater. The MCV pump (steering, TA, brakes, and lube is supplied by the 9 GPM pump. The PTO unit had the 3 gpm pump. Here are some other specs- 42 gallon fuel tank, 1000 RPM single shaft PTO unit or 540/1000 dual-shaft unit (most common), one or two hyd vavles, fast hitch or 3-point. There was also a 856 Custom, basically a stripped-down 856 to compeate with the JD 4000. These have a 37 gallon fuel tank, a single element air cleaner (no inner saftey filter), and only one headlight in each fender.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
