Re: Bolt sized and thread?
Posted by CNKS on January 05, 2005 at 18:10:07 from (204.249.178.138):
In Reply to: Bolt sized and thread? posted by SAm in NS on January 05, 2005 at 17:35:36:
Looking at my parts manual, and not going and looking at my tractor for to verify, AND assuming you mean the bolts that attach it to the engine block: two 1/2-13NC x 1 1/2's, four 1/2-13NC x 1 3/4's. There are also four 2 1/2" others for the housing (I'm not sure what those are). I believe (diagram is not comletely clear to me) that the two 1 1/2's go through the flange on the housing into the block, and the four 1 3/4's go through the flange on the block into the housing. It appears that all are blind. If I go look at my tractor, it's probably make a liar out of me. The other 4 bolts mentioned above may attach the torque tube to the transmission case, as the listing for the transmission case doesn't list any bolts. Those are probably blind, to prevent any oil from leaking around them.
Post a Followup
Subject:
