Re: Long story for an act of stupidity
Posted by Andy Martin on January 06, 2005 at 05:48:23 from (64.219.39.195):
In Reply to: Re: Long story for an act of stupidity posted by ericlb on January 05, 2005 at 18:29:53:
As much as flashback preventers are recommended for oxygen and acetylene tanks, there is no way a flame can burn down a closed line UNLESS there is a combustible mixture in the tank to start with. Backflow of oxygen into the acetylene tank is why you need a flashback preventer.
If you have only acetyelene in the tank, and only oxygen in its tank, if you get a fire in a hose the products of combustion (co2, co h2o) prevent the fire from going far down the line.
A little like dropping matches in a jar to make a lantern when you were a kid.
Post a Followup
Subject:
