Re: Farmall C camshaft reality
Posted by lee on January 06, 2005 at 18:13:42 from (24.24.95.246):
In Reply to: Re: Farmall C camshaft reality posted by Opa A on January 06, 2005 at 17:22:31:
the valve installed height can be an issue if they didn't get it right at the machine shop.
too tall or short valve installed height will affect the rocker geometry and valve timing. If the height is correct as you say, then I agree with OPA you just have to nest the towers down as they are held up by some of the valves when you install the rocker shaft assembly.
Post a Followup
Subject:
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
