Re: Oil bath Air breather?
Posted by REA on January 08, 2005 at 08:20:16 from (65.99.135.124):
In Reply to: Oil bath Air breather? posted by Bill Gray on January 08, 2005 at 06:57:54:
Hi Bill,
I stand to be corrected, but the oil breather helps keep the dust out of the carburetor better than an air breather. There is less maintenance so less expensive to use. Farmers often operate their equipment where there is very dusty conditions. Though if you are to operate your tractor for pulling at tractor shows, I understand that the air filter is somewhat better because the air intake is optimized. I hope this helps.
Bob
Post a Followup
Subject:
