Just One Tractor
Posted by Joe on January 09, 2005 at 08:55:50 from (63.246.198.39):
Hello,
I could use some advice from you guys that have been there and done that !
I have about 10 acres of fields , 1/2 of it I use for pasture for cattle the other 1/2 I am going to plant in Hay this spring.
Last fall I had a excavator come in and remove all the sod,stumps and rocks from the 5 acres that will be a hay field.I have put down lime and manure and will seed just as soon as I can this spring .
I need a tractor to plow ,disc,spread manure,mow, rake and bail hay on these 5 acres
I can only afford one tractor ,I will probably have to hire somebody to bale the hay the first year or two untill I can afford the equipment but would like to do as much as possible by myself.
What tractor should I look for ?? I only have about $3000. to work with .
Thanks for your time,
Joe
Post a Followup
Subject:
