Re: Case-IH clutch spring
Posted by Bernard le mécano on January 09, 2005 at 19:45:33 from (207.134.158.53):
In Reply to: Re: Case-IH clutch spring posted by Gene Purser on January 09, 2005 at 14:25:55:
Hi GENE , the Teflon washer have three notch that aling with the three finger bolts. The spring keep a pressure on the bearing to keep contact on those parts. When the spring is broken, the bolts worn the Teflon washer badly. You can check by the cover under the clutch. The problem with a clutch release bearing that turn all the time, it is worn rapidly.
Bernard le mécano Québec Canada
Post a Followup
Subject:
