Re: 560 power steering leak
Posted by Aces on January 10, 2005 at 15:22:38 from (65.54.98.160):
In Reply to: 560 power steering leak posted by Scotty - mn on January 10, 2005 at 09:29:08:
Scotty the radiator frame is the steering cover with an O ring under it that could leak then there should be hyd line with banjo fitting and 2 o rings this takes the oil pressure to the front side of the rack, it could leak. You will have to pull the radiator and see where the leak is.
Post a Followup
Subject:
