Re: Farmall 'B' front engine pulley
Posted by John *.?-!.* cub owner on January 11, 2005 at 07:05:26 from (208.54.220.24):
In Reply to: Re: Farmall 'B' front engine pulley posted by El Toro on January 11, 2005 at 04:12:32:
The notch is 2 1/4 inch and the plate is 1/2 inch thick. Might be able to use something thinner, but I have broken a 4 ton gear puller doing that job, and it is a pretty good strain on a 5 ton hydralic jack. If you are working on something other than a cub you would need to measure the notch, I don't know if others would have the same size neck on the pulley. The local welding shop charges $35 to make the brakcets and I can ship them for $8.00. I've opened my email if you ahve any questions or want them to make you one. They are not fancy, just cutout with a torch.
Post a Followup
Subject:
