Re: Crank bearings
Posted by Andy Martin on January 11, 2005 at 14:04:45 from (64.219.39.195):
In Reply to: Re: Crank bearings posted by CNKS on January 11, 2005 at 12:54:36:
With the engine upside down you should put the plastigage in the rod bearing, not the cap.
If the crank looks good and the machine shop passes it then by all means going with the bearings that fit, 001" under or whatever is the thing to do. A good machine shop should steer you right.
We put a Case backhoe together last year with rods a little loose (0.003) and so far so good. Works every day.
Post a Followup
Subject:
