Re: hit and miss engine
Posted by Fred Milner on January 11, 2005 at 15:49:52 from (24.159.40.134):
In Reply to: hit and miss engine posted by dexter on January 11, 2005 at 13:08:37:
If it is an IH LB engine you will need to take the mag loose and move the timing 1 tooth at a time until you get it right. Just look at the position it is in now and the direction of rotation and ajust form that point. Mine did the same thing when I got it but workes good now.
Post a Followup
Subject:
