Re: Who has rebuilt a touch control block on a sa?
Posted by scott#2 on January 11, 2005 at 16:54:26 from (141.156.130.249):
In Reply to: Re: Who has rebuilt a touch control block on a sa? posted by WalJohn on January 11, 2005 at 16:10:51:
Yes just the orings and gaskets. Ill have to check the valves as you mentioned. What problems do they cause? Did you replace them? If so how much$ were they?
To MN SCOTT, I wouldnt boil the block. There are some tight tolerences in there and fine finishes on the bores that orings ride in. Use fresh new solvent and treat all disassembly/assembly like a surgical operation.
One thing that is stated again and again in the answers I received was CLEAN, CLEAN, CLEAN.
scott#2
Post a Followup
Subject:
