Re: Crank bearings
Posted by Opa A on January 11, 2005 at 17:25:06 from (161.184.52.34):
In Reply to: Crank bearings posted by CNKS on January 11, 2005 at 10:00:41:
Measuring clearance with worn bearings and plastigage will not tell you whether the wear is in the crank lournal or the bearing shell. If the bearings are original they will have the wear as they are much softer than the crankshaft. Someone may have already replaced the bearings and then you would have to suspect more journal wear. Most bearing manufactures stamp the bearing date in the back of the shell, as well as dimension, STD, 0.010, etc, this can be a good indication of service life. I've often done 3 to 4 bearing rolls in one engine before the crank needed work. Measure the crank, and if the results are within specs (specs may already be a standard undersize) and you can't feel any grooves with your finger nail I'd just install new bearings and run it. I remember doing an engine in a Case W14 loader and the guys that work on the all the time advised me that if I had the crank turned 0.010 under it would break within 500 hrs, (only engine I've ever seen with that weak of crank). Just the same I don't like to undersize a crank unless needed.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
