Re: M temp. gauge replacement
Posted by Bob M on January 11, 2005 at 17:51:54 from (69.201.120.79):
In Reply to: M temp. gauge replacement posted by Superpicker on January 11, 2005 at 16:10:38:
If your M has a non-leaking radiator pressure cap, you do it with the motor cold, and you it QUICKLY, you can swap out the gage bulb without draining the system and will lose only a splash of coolant.
Keep in mind the original bulb screws into an odd, straight thread female x 1/2"(?) IPT male reducing bushing that's screwed into the head. Depending on the threading on your replacement gage bulb you may need to swap that bushing too.
Post a Followup
Subject:
