Re: More crank bearings
Posted by Josh In Indiana on January 11, 2005 at 18:52:15 from (65.112.65.110):
In Reply to: More crank bearings posted by CNKS on January 11, 2005 at 18:19:12:
CNKS, How are ya this evening.
You ask, "how can I tell when a crank needs to be reground?"
If it were me I would run my fingers over the crank and feel if it is groved or not. I would also look to see how it is wearing. Like if it is more wore on the sides than the center or vice versa. If there are already inserts there then chances are that someone has been there before and ground the crank and put those inserts in. Its just a guess. Depending on your use of the tractor could influence your decision. If it is out of round, meaning egg shaped then I would definetly have it ground. If its not out of round and not wore bad I would have my machinist find me a set of inserts to put in that would bring it back up to clearances and run it. Those cranks are pretty hard and they can take alot. Sorry for getting a little long winded.
Good luck,
Josh in Indiana
P.S. Those inserts should have a number on them. e.g. 5 or 10 thousanths. that is how thick those inserts are. Look up to see that the righg gap is and then that will tell you if someone has been there before or not
Post a Followup
Subject:
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
