Re: More crank bearings
Posted by Bob on January 11, 2005 at 18:53:13 from (66.163.134.177):
In Reply to: More crank bearings posted by CNKS on January 11, 2005 at 18:19:12:
You can get UNDERSIZE inserts, such as .002", if the crank is not too grooved or out-of-round.
When the crank is worn excessively out-of-round, the problem you run into is that you still need adequate oil clearance between the crank and bearing, at the LARGEST diameter of the crank, but yet there will be excessive clearance at the worn part of the crank, possibly leading to "knock" and early bearing failure.
If you have the engine all apart anyway, and are buying new bearings already, ask a machinist you trust to check out the crank. If it needs grinding, you should be able to get it done for $60.00 to $150.00, and do the overhaul RIGHT.
Saving the cost of a grind, while it's all apart already isn't going to look very cost-efective if you put it back together, and have a knock, or low oil pressure.
Post a Followup
Subject:
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards ... [Read Article]
