Re: M wheels
Posted by CNKS on January 11, 2005 at 19:02:11 from (204.249.178.138):
In Reply to: Re: M wheels posted by sammy the RED on January 11, 2005 at 18:41:12:
I meant that "usually" a wider tire is taller, which will increase ground speed, probably decreasing pulling power, since the engine has a larger tire to turn. The kids with 33 inchers on their 4x4's get around that by changing the rear rear axle ratio, hard to do on a tractor. Not saying that's always the case though. Conversely a wider tire, within reason, should result in more traction, thus more effective HP. Thus a 14.9 may be fine on an M, but perhaps not on an H. I'm getting into this more than I have knowledge or experience with, so will shut up.
Post a Followup
Subject:
