Re: More crank bearings
Posted by CNKS on January 12, 2005 at 17:52:58 from (204.249.178.138):
In Reply to: Re: More crank bearings posted by lee on January 12, 2005 at 17:04:50:
I notice the link indicates how to determine the taper, or difference in clearance at the edges of the bearing and also indicates that approximate out of roundness can be checked by checking in two locations. Reading between the lines, this to me indicates that it can be used for checking clearances of old bearings, although it is not a substitute for a micrometer. After reading it is obvious that I have not used it absolutely properly, will do so when I reassemble. The rest of you that responded might look at the link, also, it is from the company that makes plastigage.
Post a Followup
Subject:
