Re: Grinding hay
Posted by Lance R. on January 13, 2005 at 06:00:02 from (63.74.87.234):
In Reply to: Re: Grinding hay posted by Allan in NE on January 13, 2005 at 05:17:56:
The operator's manual for the grinder mixer talks about grinding hay with it but makes no mention of which size screen to use. I thought I would just feed the hay through the hammermill and not allow the hay into the build up in the tank but run the unload auger into a wagon while I grind. In other words I'd just be using the hammermill portion because I have nothing to mix. I don't know of anyone with one of those hay griders like you pictured allan. I'm located near Fort Dodge, IA.
Post a Followup
Subject:
