Re: Grinding hay
Posted by Chas K. on January 13, 2005 at 07:25:33 from (209.152.87.25):
In Reply to: Grinding hay posted by Lance R. on January 12, 2005 at 20:55:09:
Lance,
I"m with Cmore on this. We"ve also ground a lot of hay into rations. But that was in a grain mix. Not sure if you are going to want the unloading auger going at grinding RPM"s since it will be basically empty. And since you"re not talking about huge quantities...you may be able to grind a bit/unload a bit. You"ll just have to work out how much to do at a time. Worst comes to worst, you may need to through a bit of grain in to get it to come out. JMHO
Post a Followup
Subject:
