Re: Grinding hay
Posted by Mo Hay Baler on January 13, 2005 at 15:44:02 from (69.27.212.175):
In Reply to: Re: Grinding hay posted by Allan in NE on January 13, 2005 at 05:17:56:
I have ground a lot of hay through my grinder with grain for dairy rations.I use an ear corn screen.It jerks it right on through there,if you dont dump a half a bale at a time.It is a little slower with just hammers,but its worth it to be able to auger the mix into barrels or right into the trough.The old Wetmore hammermill does a better job of grinding hay,because it has hammers.I have taken it and blowed a big wagon load of ground alfalfa onto it for later use.Some mixmills have a HAY ATTACHMENT,but I have never seen that they are much better than flaking it off and feeding it though.
Post a Followup
Subject:
