Re: M wide front end Questions
Posted by Eastsider on January 14, 2005 at 09:34:42 from (204.73.192.210):
In Reply to: Re: M wide front end Questions posted by Ripper on January 14, 2005 at 09:19:13:
third party image
I have both an H and an M with the original style wide
fronts. I do not have the plates attached, so you can
see how far they will stick out when mounted where
your normal pedestal would go. They were common to
certain areas of the country. I live in Northwestern
Minnesota, and the potato and sugarbeeet farmers
used them a lot. The setback plate allowed the tractor
to be used with a front loader and to turn in a shorter
radius.
Mark
Post a Followup
Subject:
