Re: 3 pt hitch
Posted by CNKS on January 14, 2005 at 09:59:59 from (204.249.178.138):
In Reply to: 3 pt hitch posted by derf on January 13, 2005 at 21:07:28:
I have had good luck with Saginaw on both an H and a C. I tend to agree with FC on the lift height, and that the C won't take too much weight on the rear before the front lifts, but otherwise ok. The front end can be weighted. The H and larger handle the weight much better. The Saginaw is very heavy duty and may be a little overkill for the C, but it does increase the capabilities of a tractor without fast hitch. Worksaver on a C uses the rockshafts, Saginaw has it's own cylinder which is better. One thing I have not seen much discussion of is that the aftermarket hitches are axle mounted. For heavy use, such as tillage, the semi-mounted plows were designed to pull from underneath, so you don't want to overload the 3-point, and you must keep the mounting brackets tight. I don't think I would want a mounted plow on one, but I haven't tried. Fast hitch at least partially pulls from underneath, the other parts are mostly frame mounted, rather relying on the axles. Same with the factory 3 points on the later models.
Home
| Forums
Today's Featured Article -
Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
