Re: Questions about electrical system
Posted by Bigdog on January 14, 2005 at 10:55:18 from (24.160.187.179):
In Reply to: Re: Questions about electrical system posted by David Matthews on January 14, 2005 at 09:56:45:
Dave - polarizing the generator can be done with a light gauge wire. # 16 or close will be fine. It is just a momentary contact and you should see a slight spark when you touch the wire. The fact that the battery nearly blew and that it swelled up confirms that it is shot. Probably due to the generator trying to charge the battery in the reverse direction. I'd replace the battery, then concentrate on getting the starter to crank over and then attack the other problems. One step at a time will keep you from banging your head against the wall so much. (Been there - done that)
Post a Followup
Subject:
