1066 info?
Posted by becker on January 14, 2005 at 17:31:59 from (198.230.166.20):
Purchased a '73 1066 from a buddy last fall. It's gear driven with a T/A, red cab. Buddy told me a 1086 engine was put in it when he bought it. Does this sound plausible and if so what where the horse powers of both engines? I've seen some pretty high numbers on the forum. Did the red cabs come out later than the white cabs? Clutch works good but no back pressure on the pedal, just found a broken spring, does this make sense? Knocks in third gear, believe a tooth is gone, rolled the cab back to work on ranges, but don't plan to go into the gears just yet. Brakes are slow to react and seem poor....is this just set up, linings or is there a hyrdraulic problem...steering and else seems good. Hydraulic levers sticky, is this in the spools and is there a rebuild kit. Any and all info greatly appreciated.
Dorn
Post a Followup
Subject:
