Re: tachometer drive replacement
Posted by Jim J on January 14, 2005 at 18:01:15 from (65.222.50.165):
In Reply to: tachometer drive replacement posted by L.B. Novice on January 13, 2005 at 22:22:43:
The early drives were held in with clips like the gas distributor. The later type was driven into the block. You can try to pull it out of the block, but more than likely you will have to remove the oil pan and drive it out from the bottom.
Post a Followup
Subject:
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
