Farmall Tractors Discussion Board
Re: F-12 {approx.1936 or 1937} fuel pump not pumping?
Posted by MikeH(Tx) on November 27, 1999 at 15:53:56 from (208.2.106.188):
In Reply to: F-12 {approx.1936 or 1937} fuel pump not pumping? posted by Bob on November 27, 1999 at 09:33:46:
Paul is right, rebuilding is easy on these.
However, before you start, check two things - or one thing twice, depending on your definition.
The valves regulating intake and outflo are just little hexagons of bakelite, held by springs. Carefully remove the cap nut from each, and don't lose the pieces when the gas trapped in the line pushes them out of their seat. (Have the gas line turned off first). Clean each, and the metal it seats on with a Q-tip and try again.
The other thing to know about these machines is that the fuel pump is very very marginal all the time. A lot of folks disconnect the fuel line from the carb and use a gravity feed from an external tank to start things off. I use an old tiller tank.
After getting things pumping, get rid of the external tank and you are back to normal.
Post A Followup
: Re: Re: F-12 {approx.1936 or 1937} fuel pump not pumping?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
