Farmall Tractors Discussion Board
Re: Need your help on a GM 292 6 cylinder engine.
Posted by Greg Martin on November 27, 1999 at 16:57:19 from (216.128.143.195):
In Reply to: Need your help on a GM 292 6 cylinder engine. posted by The Red on November 27, 1999 at 14:30:12:
Did you pull the dist.??
I have seen harmonic balencers slip, Remove #1 plug, put your finger over the hole, crank till you feel compression, rotate by hand till piston is at TDC, dist should be aligned, don't remember if camgear is fiber or steel,
Are all rockers moving?? Any rockers leaning?
Rollpin in dist gear sheared? Broke valve spring?
Intake manifold tight? Rocker studs same height??
Stay tuned,,,,,,,,,,,,,, Greg
Post A Followup
: Re: Re: Need your help on a GM 292 6 cylinder engine.
