Farmall Tractors Discussion Board |
Re: Need your help on a GM 292 6 cylinder engine.
Posted by ltf in nc on November 27, 1999 at 16:57:29 from (206.228.213.232):
In Reply to: Need your help on a GM 292 6 cylinder engine. posted by The Red on November 27, 1999 at 14:30:12:
Remember me, we chatted prior to making your purchase. Since we don't know much history on this engine, lets just make in run and go from there. Forget about the timing marks. Remove the valve cover and the distributor cover. Rotate the engine (direction of normal running/cranking) and verify that ALL valves are moving. Bring no. 1 cylinder up on the compression stroke. Shake both exhaust and intake rockers to see that they are off the cam and thus have clearance. Verify that the no. 1 wire from the distributor is on the plug in no. 1. Look to see if the distributor rotor button is lined up with the no. 1 location on the distributor cap. If it is not pull the distributor and reinstall it until it does. The distributor will initially have to be started back into the hole a little off from the desired final location as the gear will cause a small amount of rotation of the distributor as it seats. Leave the distributor locking tab loose so that you can rotate(advance and/or retard) the distributor as you crank the engine. It should run. Good luck, owning this green beast you will need it.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
