Re: starter is smoking on my M
Posted by CNKS on January 16, 2005 at 14:36:37 from (204.249.178.138):
In Reply to: starter is smoking on my M posted by North_ Caroloina_Nick on January 16, 2005 at 14:13:30:
Positive ground, the starter doesn't care, the regulator, if designed for 6 volts positive ground, won't last as long with negative ground. A starter won't crank a stuck engine--something has to give, thus the smoke. Put the tractor in 5th gear and try to move it by pushing on the rear tire, see if the fan turns, if not it's stuck. It is possible that the starter is jammed against the ring gear, loosen the starter and push on the wheel. If the engine is loose, clean all your connections and reassemble. Take it out of gear. If the starter doesn't work then you have a starter problem. You may have ruined your regulator, also, but that shouldn't keep the starter from working.
Post a Followup
Subject:
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
