Re: TA Problem?
Posted by K.B.-826 on January 16, 2005 at 15:07:29 from (209.163.43.34):
In Reply to: TA Problem? posted by PAULIH300 on January 16, 2005 at 11:39:56:
Definetly sounds like your ramp and rollers are on the way out. The Mechanical TA used in the smaller IH's is a planetary unit. It is made up of an input shaft, a 7" clutch, a planetary carrier, the planetary unit, the overrunning clutch, known as the ramp and rollers, and the output shaft. Power enters the unit through the input shaft from the engine clutch. When the lever is ahead, (DD), the 7" TA clutch locks the input shaft to the planetary carrier, and the whole assembly rotates as a unit, resulting in no reduction of speed. When the lever is pulled back, the TA clutch disengages, allowing the power from the input shaft to enter the primary sun gear in the center of the planetary unit. The primary sun gear turns the primary planet gears, which are attached to the secondary planet gears, which turn the secondary sun gear, which is splined to the output shaft, resulting in the gear reduction. If the planetary carrier wasn't held still with the lever back, it would just freewheel around the planet gears, and the tractor would not move. This is why the overrunning (one-way) clutch, or ramp and rollers, is used. It is located between the output shaft and the planet carrier, and locks up whenever the planet carrier tries to turn faster than the output shaft. If it goes bad, the planet carrier will just freewheel. One more thing about the ramp and rollers- since it is a one-way clutch, it will lock up whenever the planet carrier tries to turn faster than the output shaft. However, if the output shaft tries to turn faster than the planet carrier (traveling downhill in TA) the ramp and rollers will overrun, causing the tractor to freewheel right down the hill. That is why you never go downhill in TA.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
