Farmall 504 Hydraulic fluid level indicator plug l
Posted by jessboyd on January 16, 2005 at 16:18:43 from (24.119.163.28):
Sorry for this stupid question, but where is the hydraulic fluid level indicator plug for a Farmall 504 gas tractor? The manual says it is "the cap screw opening in the hex. head plug (25) in the left side of the transmission case." The drawing of the tractor places it down near the clutch pedal on the left side of the tractor. Hard as I try I can't see one. I see a 1/4 inch cap screw in a 90 degree block in a hydraulic line coming out of the left side of the tractor. I see a bolt-plug in the hex flange out the right side of the tractor--where the hydraulic pump(s) are. There is a clutter of hydraulic lines that may be blocking a clear view of the plug. A description of distance and direction from a known point would sure help---like "3.5 inches in a 1:30 o'clock direction from the rear bolt holding the tractor mounting step" would sure help. Thanks in advance.
Post a Followup
Subject:
