Re: starter is smoking on my M
Posted by farmalljim10 on January 16, 2005 at 17:09:52 from (66.244.93.65):
In Reply to: starter is smoking on my M posted by North_ Caroloina_Nick on January 16, 2005 at 14:13:30:
You might have to pull the starter because if the starter is stuck in the engine will never turn over till you disengauge the starter.. I bought a 140 once locked up tight as a drum put oil in cylinders for 2 weeks still no good. So I thought I will pull the starter and try to pry on the ring gear.. Well I found the biggest mouse nest I ever saw and it had wrapped in the starter gear and flywheel so starter was engaged and would not turn .. Then tractor started right up I sold it to buy a M and a H and still had money for a $60 basket case...
Post a Followup
Subject:
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
