Re: International 560
Posted by CNKS on January 17, 2005 at 18:55:51 from (204.249.178.138):
In Reply to: International 560 posted by LBH on January 17, 2005 at 14:53:10:
Do as the others say and get a three point adaptor. If you remove the fast hitch and use an aftermarket three point, you will be bolting it to the axle housings. Thus the setup will be weaker than the fast hitch, which is bolted to the rear end housing and also underneath the tractor. As to cat 1 or 2, the pins that attach to the lower links are spaced wider and are larger than cat 1, the upper link has larger holes. Possibly the adapter will have both size holes. Category 1,2,3,4, etc get bigger and stronger as the number goes up. Cat 1 3 point implements can be used on a cat 2 hitch by using sleeves to adapt them to cat 1 pins.
Post a Followup
Subject:
