Re: The Best Paint???????
Posted by Gordo on January 18, 2005 at 09:19:42 from (64.68.166.234):
In Reply to: Re: The Best Paint??????? posted by CNKS on January 18, 2005 at 07:24:02:
CNKS is correct. Use either of the ueretahnes. MUCH beeter than the OLD acrylic enamels. Recommend a one stage paint , no clear coats.
When spraying you wait til you can just rub the BACK of your index finger along the surface, then recoat. Try to get extra coat on the sharp convex areas, as this is where you will polish off the most.
95 % of a great looking paint job is done BEFORE you apply the paint. Proper primers and sealers.
When you buy paint be sure and get the mfg "counter guide" or spec sheet and follow the instructions!
Then heat the shop up to 70 degrees minimum and start painting
Gordo
Post a Followup
Subject:
