Re: 3 Bolt Starters
Posted by DWV on January 18, 2005 at 10:04:31 from (152.163.101.13):
In Reply to: 3 Bolt Starters posted by Leee on January 18, 2005 at 08:25:15:
Unless you have a diesel or a later SM tractor
the clutch housing has been changed sometime.If
starter has engaging switch on top with a rod to engage its later SM style starter.Several other starters would bolt up or could be made to work though.Without picture or discription,Don't know which starter you have.My opinion on why IH went to 3 bolts is less breakage and the use of same
clutch housing on later SM and SMD instead of two seperate Housings for Diesel and Gas.One other thing,later on IH sold replacement clutch housings
that were 3 bolt starter.Same M starter with different drive housing.
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
