Farmall Tractors Discussion Board
Re: Re: Re: Farmall H hydraulics
Posted by pete-Tex on November 27, 1999 at 21:13:49 from (205.188.197.47):
In Reply to: Re: Re: Farmall H hydraulics posted by Pat on November 26, 1999 at 11:17:10:
The pipes coming out (one on the left and 2 on the
right are standard 1/2 inch pipe nipples (3 inch,
I think). After the pump is installed you screw
the nipples in thru the side of the case. There
should be a large felt washer under a steel washer
that fits over the pipe and keeps dust out of the
case. The washers are held in place by a spring
held under L or cap fittings on the outside end of
the pipe. These washers are not crucial, but I
wouldn't plow or brush hog without them. Be
careful that pump is tough to put in while sitting
or kneeling. Best use headless long bolts for
guides and a small floor jack t
Post A Followup
: Re: Re: Re: Re: Farmall H hydraulics
