Cleaning Battery Posts
Posted by Andy Martin on January 19, 2005 at 08:28:52 from (64.219.39.195):
In Reply to: Re: Rewind the generator? posted by Gerald J. on January 19, 2005 at 07:38:30:
Lisle makes a mill for battery posts and cable terminals that works great. It is a tapered plastic handle about 4-inches long with four stainless steel blades. They are sharp and at the angle for posts and terminals. You stick the four blades in the terminal and twist it to shear off the high points. It will mill out a very good conical shape inside the terminal. Same thing outside the post.
The wire brushes just take off the soft parts where the mill straightens it all up.
It is expensive, maybe $10 at auto parts stores.
Post a Followup
Subject:
