Re: Tanner you out there?
Posted by tanner clark on January 19, 2005 at 16:52:31 from (69.243.23.210):
In Reply to: Re: Tanner you out there? posted by Tanner Clark on January 19, 2005 at 04:41:29:
Thanks for the replies guys. I might have to take you up on that offer MagMan, because there seems to be a lot of little things that need adjusted. I started to take the Governor off tonight so that I can clean it up, and join it to the carb prior to installing both pieces, and see if that is possible. One thing on the carb, is that both of the slot things (things that look like quarters in the carb are very tight, I noticed this when I took it off tonight.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
