Re: Need more HP out of my H. Any ideas?
Posted by ChadS on January 20, 2005 at 09:52:15 from (4.224.132.188):
In Reply to: Need more HP out of my H. Any ideas? posted by Phillip w, on January 19, 2005 at 14:07:33:
PhillipW, Tear the engine down, pull out the sleeves, insert a 350 piston kit (3-5/8 bore) Sleeve and piston kits are around 350-400 bucks if you find the right place. And thats for everything,, Run the 350 head gasket. Depends really, on what casting you cyl head is,, for a couple hundred bucks you can swap the old H head out for a 350 head, while you are at it, you can also install a Super H-350 camshaft. Most 350 piston kits are firecrater pistons, which are a good piston design for making torque. Thats what you can do to the block and head,,, now on carbs, distributors and governors. If you replaced the manifold, and used a Super H-450 carb, you will pick up a few free HP, rejet the carb, and metering stem, run a better grade gas in it, the HP increases more. Tear apart the distributor, if you know what to do,,, Underneath the points plate, there is a mechanical advance mechanism. it consists of a set of weights, 2 small springs, and the rotor shaft. 9 out of 10 Farmall tractors that come in to our repair shop, the advance is stuck, broken, or so sloopy from being worn out, it suprizes me that they ran! You can replace the springs with the stock springs, or ones from a Chevrolet HEI distributor used in the small, or big block chevys. The lighter springs will give you some pep in your throttle responce. If its is a running tractor,, has good compression across the cyls, there may be room for a few more hidden ponies there,, not much,,, but, it would be enough to notice while operating it. Best advice at the moment, is to look at your spark plugs,, if they are very light in color, you need more fuel,, or a bigger carb. Feel free to email me on how to rejet the carbs, rebuild the advance unit, governors, and any other IH hop up questions that work!! Hope some of this helps! or you can call, 574-893-1032 for technical information and perfomance parts. also, 574-893-7437 for the shop. Hope this helps, ChadS
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
