Re: Trailer shopping
Posted by Dixieland on January 20, 2005 at 16:44:16 from (64.91.26.64):
In Reply to: Trailer shopping posted by Nebraska Cowman on January 20, 2005 at 15:20:50:
I have a 25 ft. dovetail gooseneck with fold down ramps and helper springs. I carry a seperate center ramp for tri-cycle tractors. One large ramp is to heavy. It has the 12" beams and can haul 10,000 lbs easy or two tractors at one time. If you can, be sure to have brakes on all axles and use Goodyear Radials because they won't heat up. The only drawback I have is the height of my trailer but tractors load easy. It just gets hard on an old man when I have to climb up at the front or sides.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
