The H that would be a B
Posted by cbox on January 20, 2005 at 22:33:58 from (192.55.52.2):
I posted a message here a couple of weeks ago about my Farmall H that sounds like a JD B. Based on the helpful suggestions received here I changed spark plugs, spark plug wires, checked the distributor thoroughly and checked the compression on each of the cylinders. They consistently measure 85-90. No cylinders are lower than that range. The fuel filters are cleaned as is the sediment bowl. Hooked everything back up and started it. Started hard and still sounds like my JD B with black smoke and the occasional flame up through the stack. Still has zero power. I'm looking for more suggestions. What do I do next please.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject:
