Re: H Steering shafts
Posted by Slappy on January 21, 2005 at 02:06:53 from (143.88.86.44):
In Reply to: H Steering shafts posted by Gordo on January 20, 2005 at 19:30:57:
I have a similar condition with my H. I'm not sure what the answer is, but I'm considering having a bushing put in. The problem here is the existing wear in the shaft. The bushing would need to be reamed to accommodate the largest shaft diameter, so even with the new bushing you will get some play. The best solution may be to have the shaft welded up and turned down to the correct size and then insert a brass bushing. Sounds expensive to me.
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
