Re: Just bought a Farmall M and need a little help
Posted by Ron in Nebr on January 21, 2005 at 21:41:21 from (65.172.143.95):
In Reply to: Just bought a Farmall M and need a little help posted by horseman1 on January 21, 2005 at 18:25:53:
From the way I read your question, there's no battery in the tractor at all now and you plan to just throw in the 12v and fire it up to run it on the trailer.
If that's the case, you'd be wise to follow the other post's advise and unhook all the wires that go to everything but the starter and the coil(if it's a points ignition). I don't know if it'd burn up the coil in that amount of time or not, but it probably could.
Unless you plan to convert this to a full 12 volt system, you'd be ahead of the game to simply go buy a 6 volt battery now and not have to worry about burning anything up or remembering where all the wires go that you unhook.
In a nutshell, to start it, make sure the fuel valve on the sediment bowl under the gas tank is open, pull the ignition switch out to the "on" position, and start it(can't remember, been awhile since I've been on an M that hasn't had the starting system cobbled...I think there's a pedal/lever you step on). It might take just a little choke, but be careful not to flood it.
Good luck and enjoy your M!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: 65534p> :
