Re: confused about ignition switch wire
Posted by Dave (IL) on January 23, 2005 at 18:22:46 from (67.175.146.6):
In Reply to: confused about ignition switch wire posted by Georgia Boy on January 23, 2005 at 17:29:04:
You sure you have a distributor and not a magneto?
Sounds like you have a wiring harness for a mag. If you have a magneto, you don't want a wire from battery to switch to magneto!!
Post a Followup
Hide: Yes No
Hiding your address protects you from spam generators but allows you to receive email response notifications.
Subject: :
